spotlight question
Old Dec 12, 2007 | 02:46 AM
aussie's Avatar
Default spotlight question
does anyone know the brand and model of spotlight on the top of the vehicle on the tomb raider jeep, I like that slim rectangular look
Old Dec 12, 2007 | 06:22 AM
TEEJ's Avatar
Talking
You want to have the lights that were on a jeep in a movie?
There are tons of rectangular lights out there....you SHOULD base your choice on the specs...like the beam pattern, range, color temperature, etc...that you want, rather than its shape....afterall, in a movie, it could have been a prop.
or go here:
jeepsareus dot com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=JAU&Product_Co de=RTRJWLB&Category_Code=Wrangler7
Old Dec 12, 2007 | 06:37 PM
aussie's Avatar
I looked around on the net ie Quadratec, kc, ipf etc but could nt find anything quite as slim in a rectangular shape, however I noticed the lights on the tomb raider jeep just above the windscreen and liked them, i know it is extremely corny to use a vehicle in a movie as guideline but they would fit the bill, there appears to be two lights off the same mount not sure of the performance, anyone know of anything similar, thanks
Old Dec 12, 2007 | 06:41 PM
Robar's Avatar
Did you see these?
http://www.northridge4x4.com/proddet...od=WARN-220312
Old Dec 13, 2007 | 05:59 AM
07rubigreen's Avatar
On the version that Jeep released for sale they were the Hella FF75 lights:
http://www.rallylights.com/hella/ff075.asp
On the version that's in the actual movie, I can't get a good enough picture to see them well enough.
Last edited by Robar; Dec 13, 2007 at 06:21 AM. Reason: Please do not post direct non sponsor links.
Old Dec 13, 2007 | 06:05 AM
hiteck's Avatar
It does look to be 2 lights in/on 4 mounts. They almost look like a housing of some sort that the lights are inside of.
Does anyone know of a lightbar or similar winshield mounting solution for lights on JK.
Old Dec 13, 2007 | 06:21 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Try either of these threads:
https://www.jk-forum.com/forums/modified-jk-tech-2/where-can-i-find-these-jk-10381/
from the above thread:
Originally Posted by seajk
I think the lights are Hella FF75's, paired with blue fogs. Sorry don't know how to link. Check out Hella's site. The light bar was custom made for movie jeep. You can't put a top on.
https://www.jk-forum.com/forums/jk-talk-26/do-you-remember-tomb-raider-edition-15995/
Old Dec 14, 2007 | 04:55 AM
aussie's Avatar
Default spotlights
thanks happy that answers my question, I am going to buy them there is a guy in australia hid technologies that can increase the light output, iknow it sounds like alot of effort and probably easier to be normal spotlights but I like the look of those ones, thanks again
Old Dec 14, 2007 | 05:11 AM
Eternal ***erator
Your welcome.
please be sure to throw up some pics when you do it
Old Dec 14, 2007 | 08:34 AM
atomicmecha's Avatar
Default my $0.02
the closest thing i found was these...
the picture is a little screwed up, but its the best i could find. Its basically the Hella Work lamps but with clear lense instead of that wierd flood lamp lense. they are still 55w per bulb and with 2 bulbs per lamp and then 4 lamps, you are talking about a lot of power.
since its not a direct sponsor, i'll just past the link as text. mods, remove it if you want... recoverygear.com/hella . html its the 2nd one down.
but honestly, i think the ones on the movie version of the jeep are custom one of a kind lights that you are not going to find anywheres else. that or they are old versions of some off road light that isnt made anymore.
