Spray in bedliner help
So i am spraying in a bedliner today, and I have a few questions. Mainly, is the taping off. Im guessing once I am done spraying, I should pull all of the tapeing off, correct? Or is it better to let it stiffen a bit?
Are you doing your tub?
If it were me, I would wait a few minutes for it to set a little bit, but don't wait too long or the overspray will bond to the tape and rip the edge of the bedliner you laid down. So you can either pull the tape right away, or wait a few minutes. Result may be the same. But i realize you want that defined line. You can always try it first in an inconspicuous area.
I am here: http://maps.google.com/maps?ll=48.426713,-114.347060
Sent from my iPhone 4s using Verizon 3G
