spring capacity
Old Feb 21, 2011 | 01:32 PM
rj'sjeep's Avatar
Default spring capacity
Looking at lifts does anyone know the differences in the spring capacity for varying lifts? for example what is the OME heavy duty vs the Ome reg vs rough country vs clayton vs terra flex. How heavy of a front spring do you need for a winch bumper and winch. Check these out you'll see what I mean. These are stock rubicon springs.
Name:	Jeep front spring3.jpg
ID:	129702   Click image for larger version
Name:	Jeep winch and bumper.jpg
ID:	129703   Click image for larger version
Name:	Jeep spring to axle-1.jpg
ID:	129704   Click image for larger version
Name:	Jeep tire clearance-5.jpg
Old Feb 21, 2011 | 03:17 PM
renpia's Avatar
I don't know actual capacity ratings per spring per brand but visually most after market springs will be much beefier than the stock springs and able to take the weight of added bumpers, winches and heavier tires. Stock springs are rated to work with the factory weight of the vehicle so any heavy mods will cause them to sag.
Here is a 4" ProComp spring vs. stock. Much beefier: thicker & more coils
Old Feb 21, 2011 | 03:30 PM
rcdude3's Avatar
wow...that isnt much lift. With my Currie springs I had to push the axle down so far the stock DS would hit the exhaust crossover pipe and the pipe would move down.
Old Feb 21, 2011 | 03:40 PM
renpia's Avatar
The ProComp is conservative and is probably a true 4" compared to others at more like 5" but it does the job and after a 1" coil spacer it will fit 37" easy. But the point in this thread is not height, it's the heaviness of the coil vs. stock.
