spring retainers
Old Mar 12, 2011 | 03:51 AM
bigdmat's Avatar
Default spring retainers
I have seen somewhere a rear spring retainer that attaches to the lower perch and the upper but,can't seem to find it now. If someone knows who or where I can find that it would help me out. Also have a question about if the upper attachment point will it work with a coil spring spacer (1 or 1.5" ) ?
also need some advise on how to secure the front springs.
Old Mar 12, 2011 | 03:53 AM
GON WHLN's Avatar
jks spring retainers for the rear lower. Clips made by Rock Krawler for the front lower.
Old Mar 12, 2011 | 03:59 AM
bigdmat's Avatar
thanks for the quick reply
when you say front lower clips. I guess I would not need an upper for the front because of the bumpstop configuration would allow the top to reseat.
Old Mar 12, 2011 | 04:06 AM
GON WHLN's Avatar
I'm alittle unsure of the upper attachments. I couldn't find any clear info. If you have the bumpstops that replace the OEM ones then they hang lower preventing your springs from dropping out.
I am mainly useing the clips to keep my springs seated in the lower perch grooves, they move around when I flex.
Old Mar 12, 2011 | 04:37 AM
bigdmat's Avatar
I found it
https://www.jk-forum.com/forums/show...ring-Retainers
thanks Wayoflife
Old Mar 12, 2011 | 04:56 AM
GON WHLN's Avatar
ah, thats what i was looking for. The JKS only do the bottom rear. I just ordered the currie set.
Old Mar 12, 2011 | 05:02 AM
bigdmat's Avatar
yeah, that looks like the ticket on the rear.
probably go with the clips on the front
thanks
