Spring / Shock lengths?
Old Dec 2, 2008 | 11:42 PM
Brisnut's Avatar
Default Spring / Shock lengths?
Has anyone got front & rear stats on their suspension kits and even stock suspension. And any other relevant stats.
Coil Thickness:
Coil Height:
Claimed Lift Height:
Number of turns/coils:
Shock Compressed length:
Shock Extended Length:
Old Dec 7, 2008 | 07:03 AM
Cpt. Flapjack's Avatar
Default Stock
I would also be interested in the stock suspension info (2dr Sahara)
Old Dec 7, 2008 | 07:22 AM
BIGG's Avatar
Trying to find an economical way to build your own lift? I am interested in this info as well.
There has got to be a spring part number or spec info out there that can be crossed to an aftermarket number that could be purchased at your loccal parts store. Figure out shock info and I'm sure that a lift could be assembled on the cheap.
Old Dec 7, 2008 | 08:11 AM
Economical, yes, but also wanting to get the most articulation without going overboard on lift.
I read in a few posts, mostly by TEEJ, that the stock shock extended length is 22". Still looking for the compressed length to find overall stroke.
Old Dec 7, 2008 | 08:23 AM
BaltChief's Avatar
I believe TEEJ said somewhere on here that the stockers are like 15 1/2.....he also said you could run a 16 to 27 on a stock ride.....That would be allot of flex out of a stock vehicle...
PS.....TEEJ is a wealth of knowledge when it comes to this stuff......the guy scares me sometimes...
Old Dec 7, 2008 | 11:02 AM
Brisnut's Avatar
Yeah, I wouldn't be surprised if 4 door deisel springs could be a 1" lift for say a 2 door petrol. Though the shocks are probably the same on all JK's.
I would really like to find these stats so I can compare them to what my local spring shop is offerring me. We could slso use shocks from something else too perhaps, provided the rating matched the weight of the vehicle.
You also need to use this info to work out your bumpstop requirements , or to stop your springs falling out on extreme travel.
Old Dec 7, 2008 | 01:25 PM
JulietKilo's Avatar
You looking for a custom suspension build with shock lengths and spring part numbers rates and a great lot of info.
Check out https://www.jk-forum.com/forums/modified-jk-tech-2/multiple-manufacturer-assembled-suspension-lift-44547/
