Springs or coilovers?
Old Aug 26, 2011 | 08:27 AM
07 JK "bullfrog"'s Avatar
Default Springs or coilovers?
Have 4" Teraflex and wandering if the EVO coilovers for the front would be an upgrade or just a waste of money? Why are your guys thoughts?
Old Aug 26, 2011 | 08:29 AM
wayoflife's Avatar
JK-Forum Founder
definitely an upgrade. you will get a much better ride up front (especially driving fast and hard across fire roads) and you'd get outstanding flex to boot.
Old Aug 26, 2011 | 09:26 AM
Do you think I would need limiting straps? I wheel lightly about once a month, but plan on going harder and more often. Thanks for your input.
Old Aug 26, 2011 | 09:37 AM
wayoflife's Avatar
JK-Forum Founder
depends if you're planning to run 12" or 14" coilovers and whether or not you have a 6-speed or auto. if you go 12's, you'll probably be fine. if you go 14's, you'll most likely need them.
Old Aug 26, 2011 | 09:46 AM
snowbilt's Avatar
How is the manual different?
Old Aug 26, 2011 | 09:49 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Or upgrade to ELKA shocks and TeraFlex SpeedBumps. You only have to make 2 cuts for SpeedBumps and no welding involved. Big difference over standard TeraFlex shocks and bumpstops.
wayoflife's Avatar
JK-Forum Founder
your front driveshaft will make contact with the exhaust crossover. granted, on an auto, it will make contact with the tranny skid as well but, you can take that off and i would recommend doing so. better to run something like a rk hd tranny pan instead.
Old Aug 26, 2011 | 12:12 PM
Andrew@EVOMFG's Avatar
EVO MFG Representative
The EVO Coilover kits improve ride quality both on and off road. Certainly would be an upgrade. I would say a significant one.
Old Aug 26, 2011 | 12:14 PM
JK with manual transmission and 14" coilover require either limit straps or rerouting of the exhaust crossover due to the output of the front driveshaft at the transfercase of manuals being about 3" further to the rear of the JK.
Old Aug 26, 2011 | 10:00 PM
I'd go with the 12" shocks. I have an auto and have a coast driveshaft (believe I saw something about needing an aftermarket DS to prevent rubbing?) OHHH!!!! and would my swaybar disconnects work with the coilover kit? Or do I would be better buy the recommended ones that comes as an extra option? That sway area looks crammed in the photo :-/
