Sprint Booster Caused Check Engine light to Illuminate
Old Apr 18, 2012 | 03:13 PM
Sunkist Rubi's Avatar
Default Sprint Booster Caused Check Engine light to Illuminate
I just installed a Sprint Booster and I plugged the end into the harness the wrong way causing the check engine light to come on. I flipped the plug over and all is well except the check engine light is on. Will I have to visit the dealer, or will it eventually reset itself and shut off?
Does anybody see any reason why it will hurt to drive it this way, check engine light on, until I can get to the dealer?
Old Apr 18, 2012 | 04:36 PM
18usc371's Avatar
Did you leave the door open +5min before the switch?
Old Apr 18, 2012 | 05:39 PM
Yes I left the door open for 5 minutes, I also got the lightning bolt immediately after I hooked it up wrong.
Old May 22, 2012 | 06:14 PM
bowhuntr's Avatar
Disconnect the battery, turn on the headlights for 5 minutes. Reconnect and the error will clear if it was transitory.
