squeaking
So I have the 4.5" bds Suspension and it is now like squeaking when im driving between 10-20 mph. Have no idea where it is coming from but it is quite annoying haha. Any ideas???
Using the MPG setting I do not encounter the "squeaking"
I have the same type of squeak. I have not found it yet. My JK only has 5000 miles on it and it only squeaks when I am moving. The frequency of the squeak doesn't change with RPM or brake pressure. It sounds like a brake wear indicator but it is intermittent. Sometimes it squeaks all the way to work sometimes not at all.
I have noticed one of the brake lines on the rear axle is rubbing a shock. I am going eliminate this rubbing, but I don't think that it is the source of my annoying squeak.
Yes, If I stand on my side step of the driver side and jump up and down it squeaks. I just found that out. But that is hard to tell where it is coming from. hmmm
Check the rear lower control arm frame mount nuts. They have these tabs that in my case were rubbing the CA's and the side of the frame mount and making a crazy loud squeak:
Driver:
Passenger:
I ended up using a dremel with a cutting wheel to cut off about 1/4" off them so they don't rub anymore, and squeak is gone.
Driver:
Passenger:
