Squeaking question
Old Apr 1, 2012 | 09:52 AM
ColeRedRubi's Avatar
Default Squeaking question
Hey jeep experts sorry to bore you with another squeaking noise question but this one is a little different. After putting a BB on my jku there has been a LOUD squeaking noise in the rear of my jeep. I took it to the shop that did the lift and it turns out that the noise is coming from the rear track bar bushings. Apparently the new ones are made from a poly material an the old ones were rubber. They said they could put in older rubber ones (for a charge) and that "might" help the problem. Are there any write ups on this subject or any products that can eliminate the noise? Any help would be great.
Thanks guys.
Old Apr 1, 2012 | 05:26 PM
Bump need help
Old Apr 1, 2012 | 05:46 PM
finfreeze's Avatar
Spray some WD40 or PB Blaster on the bushing to see if it is the source.
I wouldn't put rubber in, especially if you wheel alot. rubber doesn't hold up as well as the poly bushings.
Old Apr 1, 2012 | 06:31 PM
EzK's Avatar
EzK
If that is truly the problem then reinstall the bushing with some lithium grease on it. That kept all the poly bushings on a lifted TJ that I had silent.
