squeaky derlin bushings
Old Feb 14, 2014 | 01:19 PM
ctjeeper's Avatar
Default squeaky derlin bushings
Has anyone who replaced their door bushings with the derlin ones found that they are quite squeaky in cold/snowy weather. Wondering if its typical or maybe my pins are mucked up. Thanks.
Old Feb 14, 2014 | 01:21 PM
ronjenx's Avatar
Mine have been in for a few years now. Not a peep out of them.
Try a dab of silicone grease on the door pins.
Old Feb 14, 2014 | 01:23 PM
ctjeeper's Avatar
This only started when the sloppy weather came on. I heard yer not supposed to lube them. Silicone is OK??
Old Feb 14, 2014 | 01:32 PM
crusaderJK's Avatar
Maybe not oil the pins but clean them.
I also had them squeak. Haven't noticed that after I replaced my hinges.
Old Feb 14, 2014 | 01:56 PM
ronjenx's Avatar
Silicone is not a problem on delrin.
Old Feb 14, 2014 | 02:19 PM
jeepmojo's Avatar
Default lol i noticed mine today when i dug it out
i dont know how people find this crap enjoyable i guess they dont have that long of a drive way a carport a shed a metal roof that drops 30 tons of white and no kids!
can you spray it or do you have to remove the pin?
Old Feb 20, 2014 | 03:03 PM
ctjeeper's Avatar
Ya.... I did clean them n it went away. Till the next batch of sloppy weather then it came back. Only one door is really bad but I have a feeling the hinges might be a lil out of alignment cuz I can feel a slight binding and that door still requires a floor jack to remove even after I added the derlins. The rest come out easy n barely squeek. Also my pins don't look like they are in great shape but I don't think they are very easy to change.
Old Feb 20, 2014 | 04:22 PM
jeeperjkjeeper's Avatar
Emery cloth the pins and apply a thin layer of white lithium grease each time the doors come off....my Delrin bushings have never made a peep
Old Feb 20, 2014 | 04:29 PM
ctjeeper's Avatar
Ahhh. Emery cloth there's an idea. I had steel wool lying around but it was pretty fine. So both white lithium n silicone are safe? Still think I need to align the bad one buti will try a few things. Thanks all
