Squeaky suspension?
Old May 10, 2012 | 09:02 PM
TURTLECON's Avatar
Default Squeaky suspension?
Took my doors off today and noticed I could hear some squeaking from (most likely) the suspension while driving. Definitely more noticeable over speedbumps in the parking lot.
So, I was wondering if anyone had any advice for me as to what parts (and maybe in what order) I should check/diagnose and maybe grease?
I have the 3" SRS Full Traction "0% Maintenance" lift kit with 4 control arms. I know, I know... SRS "silent ride system" and "Zero Maintenance" should mean I probably shouldn't be getting squeaks and noises & have to do anything, but I figure a little work to keep things running smoothly is to be expected. Should I possibly start with some white lithium grease on the bushings and CAs first?
Thanks for any help!
Old May 10, 2012 | 09:38 PM
afpilot82's Avatar
JK-Forum Ambassador
I would start with greasing everything, seems to be the cheapest & easiest start to solve the problem. If it doesn't change anything, you haven't wasted much money or time and you can continue to troubleshoot.
Old May 10, 2012 | 10:02 PM
TURTLECON's Avatar
Thanks bud. Can you define "everything"? Obviously bushings and rod ends... but what else? I want to hit the right spots & avoid greasing things that I probably shouldn't.
Old May 11, 2012 | 04:46 AM
afpilot82's Avatar
JK-Forum Ambassador
I would say just bushings and rod ends...certainly don't want to throw 10 lbs off grease under your rig. lol
Old May 11, 2012 | 04:55 AM
pfd1980's Avatar
spray all of the bushings with WD-40. i've been doing this for a while now when i get squeeks. works great!
Old May 11, 2012 | 07:28 AM
Ryan0260's Avatar
White lithium grease works great for this
Old May 11, 2012 | 07:35 AM
MTG's Avatar
MTG
WD-40 is NOT a lubricant.
Old May 11, 2012 | 07:37 AM
MTG's Avatar
MTG
Check your sway bar end links for the squeak and damage. I had a squeak too and that was the source.
Old May 14, 2012 | 10:39 AM
Rock Krawler Suspension's Avatar
Former Vendor
WD-40 or MPL on the joints will quiet them down if that is where they are coming from. If it is steel on steel for a loose connection it will not help.
RK
Old May 14, 2012 | 04:10 PM
TURTLECON's Avatar
This is the first thing I'm going to check. No, I will not use WD-40 on my bushings. It will ruin them!
Talked to Steve @ FT... I got the list of things to check for my lift. Thanks for looking out, Steve! Will keep you updated.
