Squeeking?
Old May 6, 2010 | 06:22 PM
Phoenix07013's Avatar
Ohh, well wheel bearings are known to go bad
jk20084p's Avatar
Originally Posted by Little Fella
Lets get some more description so we can properly hypothesize (sp?) this....
Does the sound pulsate? sqweek, sqweek, sqwwek , yes
Does the sound change pitch or speed with vehicle speed? no for pitch, yes for speed
It it a metal on metal sound? not really, it is a sqweek except when braking
Does the sound change with oscillation of the suspension? not at all
Do your rims get hot near the center after driving at speed? never checked...
Things we know:
Coming from the rear end.
Changes when brakes are applied.
and disspear when raining / Jeep wet
Answers in red
Old May 6, 2010 | 06:23 PM
jk20084p's Avatar
Dealer checker for that (mod friendly, installs BBL 2.5" and 35" tires...)
Old May 6, 2010 | 06:33 PM
Little Fella's Avatar
OK the fact that the squeek doesn't change with the speed of the vehicle indicates that it is not rotating with the wheels (ie: bearings, brakes etc).
Have you checked exhaust hangers?
Put your foot on the tailpipe and giver a shake....
Old May 6, 2010 | 06:35 PM
jk20084p's Avatar
Just edited the previous answer, I missed the speed factor, yes, sqweek speed is proportional to speed of vehicule, clearly is.
Old May 6, 2010 | 07:57 PM
OK well that puts us to a rotating item. I understand that the dealership has removed the wheel but have they removed the caliper and disc? The JK e-brake assembly is a great hiding place for all kinds of crap. If you've never seen it it's like a drum brake inside the disc brake. Any number of things (rocks, pebbles, sticks, dirt, the neighbors cat) could get caught in there and cause a pulsing squeek that changes with the speed of the vehicle.
Try pulling the e-brake a notch or two while driving and see if it goes away
Old May 7, 2010 | 02:36 AM
jk20084p's Avatar
That is very possible, I will try it today. In fact, the ebrake is almost dead on the Jeep...
Old May 7, 2010 | 10:18 AM
jk20084p's Avatar
Tried to pull the ebrake, no change in noise... (and not much braking either )
Old May 7, 2010 | 09:23 PM
OK so it sounds like your cable needs an adjustment.
Maybe check between the disc and dust shield for debris next (and to make sure the dust shield isn't bent into the disc).
And between the pads, calipers and disc....
Don't forget to check the pads themselves for embedded debris.
Old May 8, 2010 | 04:42 AM
jk20084p's Avatar
The brakes were verified last week by the dealer, they removed the wheels and checked, unless you mean the inner "drum" of the ebrake, I think they're reluctant to opening that up, is it difficult to open and put back together after ?
