SS Extendend Brake lines, which ones?!
So I'm going to upgrade my lift so I'm going to do the brake lines while I'm at it.
Which ones do you guys run? And how do they perform?
Crown?
Rockkrawler?
Any other brands that make them?
Crown?
Rockkrawler?
I was reading about the crowns the other day and quite a few people were having an issue with the finish of the lines, they were yellowing and frail.
Is there a noticeable performance gain in stopping power?
In theory you will have a better pedal feel because the stainless braiding prevents the line from swelling at all. However you will not have more stopping power. If you want to get more stopping power you will need to change your brake pads to a more aggressive compound pad. This will bite into the rotor more and stop you in a shorter distance.
I have the crown, however I only bought them because of the rears.
if you re-route the fronts, you may be fine.
Had I actually looked at my JK before buying the extended, I may have just done this in the front.
what are people doing about the E-brake lines? at full droop in the back, they look REALLY tight.
I re-routed the rear wheel speed sensors over the axles to gain more length in those...
