Stabilizer with beefier tie rod?
Old Jun 5, 2009 | 06:37 PM
Hellbound13's Avatar
Default Stabilizer with beefier tie rod?
If you get a beefier tie rod like the RE one how do you use stabilizer? The RC stabilzer I have won't fit, cause the ubolts just barely fit around the stock tie rod. So what are my alternatives?
Old Jun 5, 2009 | 06:38 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
someone in FL got the RC to work with the rock krawler tie rod, they got bigger u bolts and made it work
Old Jun 5, 2009 | 07:07 PM
What about a woods bracket with a diff stabilzer. Does the woods fit larger tie rods?
Old Jun 5, 2009 | 07:18 PM
edwin907's Avatar
The Rock Krawler Tie Rod comes with larger u-bolts for the stabilizer.
I'd figure you could get them from Rock Krawler if you couldn't find them anywhere else. My stock stabilizer is still good so I used them with it.
Old Jun 6, 2009 | 07:37 AM
ranwitscissorz's Avatar
Bigger U-Bolts, the RC stabilizer has one set of holes that are oval so you can fit a little big bigger U-Bolt. If that doesn't work, get the U-bolt setup from Lowes that comes with a flat bracket and just put 2 bolts with washers through it, like edwin has on his (you can see it sticking out).
