stacking spacers
Old Feb 16, 2013 | 01:36 PM
NCJohnP's Avatar
Default stacking spacers
Is it possible to add .75" spacers to TF leveling kit? I am looking for just under 3" lift and will be running 33's. I want to see if this is safe or not recommended. Thanks.
Old Feb 16, 2013 | 02:52 PM
Ryan0260's Avatar
I would just go with a different spring. You might find a set of used Rubicon springs to give you a little extra lift.
Old Feb 16, 2013 | 04:11 PM
Jersey_Devil's Avatar
Definitely don't stack spacers.... UNSAFE!!! U can find used springs on here.... I saw jku Arctic springs today for sale....
Old Feb 16, 2013 | 04:41 PM
Grand Umpah's Avatar
I'm not so sure you need more lift than the TF provides to run 33"
I've got the leveling kit and am planning to go to 33" tires when I burn off the stock rubber, and everything that I've read indicates that it won't require anything more in the way of lift.
Old Feb 16, 2013 | 04:46 PM
NCJohnP's Avatar
Thanks for the info. I already have rubi springs and shocks, just trying to plan my next move. Looks like 2.5 coil lift might be what I need. How is the TF 2.5 ride compared to what I have now on the surface streets?
Old Feb 16, 2013 | 05:43 PM
gunbo75's Avatar
X2 do not stack spacers. Just get new coils.
Old Feb 16, 2013 | 07:02 PM
CerOf's Avatar
Not true.
Teraflex leveling kit has you stack spacers.
If you retain your factory isolaters and run a BB, you are stacking spacers essentially. There is a limit as to how big of a spacer you can go, but I'm not sure what that is.
