Staun internal bead locks?
Old Nov 27, 2009 | 09:52 AM
Default Staun internal bead locks?
found some by STAUN. works on any rim, its like a little tube inside that puts pressure on BOTH beads. was wondering if anybody has run these. on the site it says tires bigger than 36" will need to have the sharp egde by the bead to be smoothed out. can't see that being much of a big deal. plus i only want 35"
Old Nov 27, 2009 | 10:00 AM
JulianK's Avatar
Never used them but Ian Johnson from Extreme 4X4 likes them and uses them and he knows his stuff.
Old Nov 27, 2009 | 10:40 AM
style_front's Avatar
I wondered about those stains as well, I wonder if it creates a problem balancing the tires?
Old Nov 27, 2009 | 10:43 AM
Piginajeep's Avatar
its Stauns,,,
They are a sponsor on the board, Send them a PM
Old Nov 27, 2009 | 10:52 AM
Originally Posted by Piginajeep
its Stauns,,,
it's an iPhone, it spells what it wants.....
Old Nov 27, 2009 | 10:56 AM
Piginajeep's Avatar
I feel your pain! I hate that about the iphone.
Old Nov 27, 2009 | 11:26 AM
Hey man, can you help me in this thread?
https://www.jk-forum.com/forums/show...=109543&page=3
Having installed your long arm I figured you might be able to shed some light on some of these questions regarding axle indexing and bracketry....
Old Nov 27, 2009 | 11:32 AM
Piginajeep's Avatar
answered
Old Nov 27, 2009 | 10:31 PM
w squared's Avatar
Some of the guys in my Jeep club run them, and I'm considering a set.
They're less expensive than beadlock wheels, and give you two advantages:
#1. They can function as a run-flat insert for a short period of time.
#2. They lock both beads...not just one.
On the downside:
#1. You can end up with an accumulation of silt between the bead and the rim which may cause some abrasion over time. This can be controlled with good maintenance.
#2. Installation requires drilling a hole in your wheel. This is not something where you can say "I don't like them, I think I'll just take them out."
The best bet is talk to people in your area that run them. They will tell you whether or not the silt accumulation is a problem for them, and hoperfully suggest a good place to have them installed. Apparently if the install is not done properly, the results are not ideal (then again, this is true for almost everything we put on our Jeeps )
Old Nov 27, 2009 | 10:55 PM
JCKnauer22's Avatar
couldn't you just put a valve stem in the hole and leave it be if you didn't like them? i don't know personally, i'm just throwing out ideas.
i've also heard that these tend to impede with the airing down process as the internal bladder tends to block the opening to the wheel's original valve stem. i don't know how true this is as it's only word of mouth, but it'd be nice if somebody with experience could chime in
