Steering Darts around with Teraflex Arms
I installed a set of 8 Teraflex control arms, set the caster to 5.5 degrees but now the Jeep darts around on the freeway. Has anyone else experienced similar problems? Any suggestions on how to fix it?
Generally, more caster tracks straighter, but has slower turn-in.
Darty handling is merely excellent tun-in.
So, generally, you add positive caster to reduce dartiness.
Plan B - if the dartiness is in response to the suspension compressing/extending, as in reacting to bumps, then its more likely bumpsteer than caster at play.
