Steering Geometry issue???????
So my Track bar holes were wallowed out, so i wanted to do more than weld washers on the axle end, wanted to strengthen the mount too. So i purhcased the Currie relocation bracket. now that I have raised the location of the TB, and causing the TB to run not parallel with the drag link.
Is this something I need to fix? I know this bracket was designed for more lift, but i shortend the tb, but am just worried that this will cause the steering geometry to get oiut of wack.
Yea I'm getting a little bumpsteer, and it feels like the handling is off just a bit. I have the JKS track bar back in now, so with that extra bend down at the rod end, its even more off from parallel than the stock tb is in this picture. I tried just putting the tb back into the original mounting position, but because the main currie bracket goes on the inside of the oe bracket, it has made it narrower so the tb won't fit down.
thanks for the input. until it gets here, is my jeep safe to drive or do i need to park it until the dropped pitman arm gets in?
I was wondering if you talked to Currie about using that bracket with your lift?
It appears that you have 2" of lift and that bracket is from a 4" lift kit (per Currie's website). Parts like that are usually designed for a range of lift.
The same holds true for dropped Pitman arms and drag link flip kits.
No I never spoke with Currie, I have about 2 3/4 up front, I know it wasn't designed for that, but I had to get something to reinforce the mount as well as address the issue with my wallowed out holes, and I didn't just want to weld on washers. Hopefully a dropped pitman arm, found one for 3"+ of lift, will help me out. So I guess if that doesn't do it, ill just have to get the tb mount and all cut off and just start from scratch with haveing a completely new mount added on in the original position. Hope it doesn't come to that.
