Steering help
Old Aug 8, 2014 | 05:00 PM
Wgrin's Avatar
Angry Steering help
I live in the road salt capital of the world, upstate NY. The salt is so bad I have to repaint the underside of my jeep 5-6 times a year. When I turn my wheels I get this sound that is hard to describe so I took two videos of it. One is at a stop and the other when going slow and turning, more so to the left than right. Any ideas would be greatly appreciated. The stopped picture sounds like a boat rocking in the ocean, but without the enjoyment.
http://youtu.be/DcCKseSZr8g
Jk turning - YouTube
Old Aug 8, 2014 | 05:56 PM
familytime's Avatar
JK Forum Regional Rep
Axle shaft u joints,ball joints
Old Aug 8, 2014 | 05:58 PM
Wgrin's Avatar
Bad news, bad news, bad news. You are thinking all 3? Or possibly one of those...
Old Aug 8, 2014 | 06:03 PM
pjmjk's Avatar
I just dealt with a bent shaft didn't have a consistent sound like that. Easy way to tell for bent shaft is put it on a lift or something you can run the wheels and see if it shimmys.
U joints or ball joints seems like a real good probability though
Old Aug 8, 2014 | 06:18 PM
Wgrin's Avatar
I had planned on changing the ball joints next winter 2015, because we leave upstate NY for Oklahoma and I would be done with the salt world. I worry if I replace them now that I am putting them through another winter here, but if they won't make it then I guess another winter is what they have in store. Nothing looks broken when I inspect it, I already planned on changing out the ball joints as I said, but I guess I can add u-joints to the list as well. It is so embarrassing turning anywhere and people look. It is almost as bad as a worn belt.
Old Aug 8, 2014 | 08:45 PM
Mountain Man Tim's Avatar
the bad part of all that salt: corrosion. this being the last winter you play with it you could break down and get under there and wash your suspension a few times a week to try and stem the flow.....
Old Aug 9, 2014 | 04:43 AM
Wgrin's Avatar
I try to under spray the body as often as possible. I am not sure if this is caused from the salt or trails--or both. It is a bad sound and I worry it'll break before I can fix it
Old Aug 9, 2014 | 08:35 AM
Wgrin's Avatar
Does anyone know if this is a safety hazard? Could I get 500 miles out of it? 1000? Only 100? Or get it to the shop now?
Old Aug 10, 2014 | 01:02 PM
Wgrin's Avatar
Anyone at all?
Old Aug 10, 2014 | 02:03 PM
Rebar-7's Avatar
Originally Posted by Wgrin
Anyone at all?
I'm thinking axle shaft U- Joint , maybe Unit bearing ? Have you tried jacking front up a little and grab the tire see if you can move it back and forth.
Push / pull for any play
