Steering Issues
Old Jul 26, 2007 | 09:37 AM
Huntr's Avatar
Question Steering Issues
I have a 4dr Sahara. I have had it for about 3 weeks. I never drove it stock-as soon as it came in I put a 3" Tereflex suspension lift and 35" toyo M/T. My problem is the steering seems overly responsive. Not sure if you would call it oversteer but it feels like driving a 4 wheeler on pavement. every move you make the jeep responds.
Do stock jeeps feel this way?
I had a TJ previously and when I had the lift put on I had the same issues. But with the TJ I was able to have it adjusted so it wasn't so sensitive. The dealership said the same type of adjustment does not exist in the JK. Does anyone know what I am talking about? As much as I like my dealership I don't always trust their info.
How do I make the steering less sensitive? Is it adjustable?
Old Jul 26, 2007 | 10:04 AM
Renegade's Avatar
It needs a castor adjustment via adjustable arms or cam bolts. You will get used to is somewhat, but it won't be "right" until you make the adjustment. Good luck. Do a search on the forum for more info.
Old Jul 26, 2007 | 10:14 AM
BLKRuby's Avatar
Check your tire pressure. When i had my tires put on the put 38lbs in them and it rode in all the grooves on the road. I aired them down to 29lbs and the difference is unbelievable.
Old Jul 26, 2007 | 10:45 AM
Huntr's Avatar
I took it in the day after I bought it to see if they could solve the problem and the did a full alignment and said everything was fine. When they do a full alignment do they adjust the castor?
Do stock jks feel this way?
Is there an adjustment in the steering box like in the TJs?
Old Jul 26, 2007 | 10:48 AM
BLKRuby's Avatar
The only way to adjust is caster is via new adjustable control arms, or cam bolts. Mine isn't that much off from the stock feel. I do plan on getting arms soon though.
Old Jul 26, 2007 | 12:20 PM
Huntr's Avatar
Do you recommend any brands?
Old Jul 26, 2007 | 12:23 PM
BLKRuby's Avatar
I am trying to find that out as well. I am thing Rusty's or Daystar. Bothare adjustable and around $750. I would rather get Full Traction but the price is a bit steep for me.
Old Jul 26, 2007 | 01:05 PM
Huntr's Avatar
thank you for the good info. after researching a few sites and reading their descriptions of caster I think you are right on as to my problem.
http://www.jeepfan.com/tech/CasterCamberToe.htm
other than control arms is there anything more that I would need to do to bring the caster positive again? in a previous post someone mentioned cam bolts???
Last edited by HappyCurmudgeon; Nov 1, 2008 at 04:50 AM. Reason: removed hyperlink
Old Jul 26, 2007 | 01:15 PM
Huntr's Avatar
Default Upper or Lower. front or rear Control arms
I found another good thread about caster https://www.jk-forum.com/forums/show...ghlight=caster.
The question I have now is which arms do I need?
Lower, upper, front, rear. I have read a few posts and most say front lower control arms. Is this all I would need to fix caster problems?
Old Jul 26, 2007 | 05:17 PM
Huntr's Avatar
Thumbs up
info about caster and fixing the aforementioned steering problem
https://www.jk-forum.com/forums/show...d=1#post138762
