Steering not straight after Offroading !?!
Hello folks... well today was the first time i take my JK for a little offroading.... nothing serious just driving on sand and bumpy gravel road. When i got back on the street i had the ESP BAS solid on, traction control stayed lit and my steering wheel was not straight anymore. Later on the traction control switched off but the ESP BAS stayed lit.
Mind u the whole driving time was less than 45mins and nothing hardcore... no dune bashing no jumping nothing... Wots goin on here?
Thanx in advance
Thanx in advance
I had the same problem with mine the first time I took it off road. I traced my problem to the trac bar drop bracket. It was letting the hole axle shift to one side, therefore causing me to have to counter steer to drive straight and the ESP would consistently kick on.
pretty typical after wheeling, your steering wheel will be off sometimes. Just follow the the write up and adjust the draglink.
http://project-jk.com/jeep-jk-write-...-end-alignment
my vote is on the drag link. if your steering wheel is straight. your tires should be straight.
if your steering wheel is straight. and your tires are not or if it is turning. check the drag link.
ten minuter.
ten minuter.
Agreed, pretty common.
Sometimes after you re-align the steering wheel it takes a few minutes of driving, or a couple of off-and-ons for the ESP light to turn off. Don't panic if it doesn't turn off right away
