Steering problems after lift
Old Aug 17, 2012 | 02:41 PM
rer292's Avatar
Default Steering problems after lift
I just installed a Full Traction leveling kit on my 12 JKU. Now the steering feel "flighty". I hit a bump and it seems to sway side to side, feels unstable. Just doesn't feel right. I did not do shock extenders and did not do a wheel alignment. I did have to center the steering wheel. Any ideas as to what went wrong would be appreciated.
Old Aug 17, 2012 | 02:45 PM
Sharkey's Avatar
I wouldn't think a leveling kit would cause the flighty feeling. Just for kicks, I'd loosen your control arm and trackbar bolts, rock the Jeep back and forth, and re-tighten everything to spec torque.
Old Aug 17, 2012 | 02:46 PM
mkjeep's Avatar
Loosen your trackbar and control arm bolts, shake your jeep, retorque, report back.
Old Aug 17, 2012 | 02:47 PM
mkjeep's Avatar
ehh, beat to the punch.
Old Aug 17, 2012 | 03:31 PM
Its_a_JK's Avatar
Sponsoring Vendor
Epic-Addictions Representative
what they said /\
Old Aug 17, 2012 | 06:34 PM
Rubicon John's Avatar
What they all said, but make sure the jeep is on the ground and under its own weight when you torque the bolts down.
Old Aug 17, 2012 | 06:37 PM
rer292's Avatar
Thanks, will report back ASAP
Old Aug 29, 2012 | 10:06 AM
rer292's Avatar
Thanks to all that posted. I did what you said and the ride is much better. I do still have squeaking but will work on that. Also think I will do the bolt change and get a wheel alignment just to be safe. Thanks again...
Old Aug 29, 2012 | 07:01 PM
Emmeljk11's Avatar
Need to do this too. It feels loose also
