Steering stabilizer?
When i put the 35's and a 2.5" BB with 4door rubicon coils on my 2door it was pretty hard to control. Had the toe adjusted and that helped a little. Aired the tires down from 30 to 25 psi and that made a ton of difference. I would air the tires down to 25 or 26 psi and see how that feels to you. I ended up getting some adjustable LCA's as well. Drives better than stock now
I didn't see what size tire you went to, but you might also look at the 'Setting Your Toe-In' section of this write-up.
http://project-jk.com/jeep-jk-write-...-end-alignment
And you may as well look at the 'Setting Your Caster' section also, since you just may end up with some adjustable CA's at some point...
My 35's wander a bit, so I thought I try and measure them. LOL with my tires that is almost impossible!
My 2.5BB was fine with 32's, but 35s and it's a tad darty. have about 5K on them now. I can live with it, but would love to try the 1/8 inch toe-in.
. that would be considered a mistake
