Steering Stabilizer
Old Feb 22, 2010 | 01:25 PM
mudy 07 rubicon's Avatar
Default Steering Stabilizer
Looking at getting one of the steering stabilizer kits. What do you guys think? I was looking at the Teraflex and ORV ones but im open to anything.
Old Feb 22, 2010 | 01:27 PM
JackMac4's Avatar
Teraflex is cheap and works. The stock one is fine too. I'd worry more about relocation than the shock itself.
Old Feb 22, 2010 | 01:28 PM
Hellbound13's Avatar
I have the Rough Country single and love it. Its beefy as hell and has a larger diameter shaft than the others. A lot of folks are running the Rough Country duals. Some say that is overkill.
Old Feb 22, 2010 | 01:36 PM
JayhawkJeep's Avatar
Veteran: Navy
This is a long thread but a good read.
https://www.jk-forum.com/forums/modified-jk-tech-2/myths-about-steering-stabilizers-55767/
Old Feb 22, 2010 | 04:32 PM
nangulator's Avatar
I went with a black diamond, it is very beefy, re-located to a higher position and cost less than 70 bucks.
Old Feb 22, 2010 | 09:50 PM
spinlock's Avatar
As long as you just want to augment steering stability and not provide stability per se any of them will work. IMO, your wasting your money on dual SSs.
The TF is a good choice.
Old Feb 23, 2010 | 03:20 AM
Yoda's Avatar
https://www.jk-forum.com/forums/showthread.php?t=55767
X2 EVERY MEMBERS OF THIS FORUM SHOULD READ THIS THREAD !!!
Old Feb 23, 2010 | 05:36 AM
grnmonsta's Avatar
Default Fox
I went with Fox racing, haven't had any issues and althoug more expensive it was well worth it!
Old Feb 23, 2010 | 06:32 AM
o7jk's Avatar
i have the terraflex. i blew out the stock one and replaced with skyjacker. that started to blow out ( could be because i had DW at the time) I replaced it with terraflex and it works fine. I installed the SS backwards with the piston on the drivers side end (piston hidden behind the tie rod) to prevent the piston from getting hit with road debris
Old Feb 23, 2010 | 07:25 AM
wayoflife's Avatar
JK-Forum Founder
yup, what he said. nothing wrong with the stock stabilizer and i wouldn't even bother replacing it if it aint damaged.
