steering stabilizer
Old Mar 27, 2010 | 07:45 AM
drc228's Avatar
Default steering stabilizer
anyone know of a performance steering stabilizer that will work on a jk with no lift or if its possible. was told i had to get a 2 inch lift for any performance stabilizer to work. just wanna know if their trying to get me to buy some stuff i didnt actually NEED.
Old Mar 27, 2010 | 08:20 AM
JPop's Avatar
No need for any performance steering stabilizer, unless the stock one is bad and even so you don't need to opt for anything more than an inexpensive one such as the one from Teraflex. It'll get the job done and if it doesn't, the problem was more involved than a bad steering stabilizer.
Old Mar 27, 2010 | 08:34 AM
goldtr8's Avatar
If your stock one is bad and you are under warranty there is an upgraded one that the dealers are putting on. I just got one on my Rubi
Old Mar 27, 2010 | 08:38 AM
CerOf's Avatar
Do you have a part number for the upgraded one?
Old Mar 27, 2010 | 08:55 AM
JayhawkJeep's Avatar
Veteran: Navy
Everything you ever wanted to know about steering stabilizers.
https://www.jk-forum.com/forums/modified-jk-tech-2/myths-about-steering-stabilizers-55767/
Old Mar 27, 2010 | 09:17 AM
drc228's Avatar
Default hmmm
well i guess i should have mentioned this but im goin with 33x13.5 15's. apparently adding 300 pounds of tires might mess somethin up. thats what i was told anyways.
Old Mar 27, 2010 | 09:49 AM
spinlock's Avatar
The stock stabilizer is already designed for 32" tires (~70 Lbs per rim+ tire), so it should readily handle the 33" tires since you are only adding an extra 10-30 lbs.
Old Mar 27, 2010 | 10:08 AM
drc228's Avatar
Default thanks
never thought about it like that. just figured that 75lb tires and a steel wheel would throw it off a little but ill try out the stock one and if it trashes it ill spend the cash on a 2 inch lift and i like the look of the dual RC ss. thanks guys.. i love this forum!
Old Mar 27, 2010 | 03:41 PM
wheezer's Avatar
These guys are right. You don't need to replace or upgrade unless your stock one is bent and/or leaking. And believe me, if you wheel even moderatley you will end up smacking it on something!
Old Mar 27, 2010 | 04:39 PM
jeepmedic's Avatar
I like my teraflex SS. Dont even notice it being there and it is cheap $$
