Steering Stabilizer
Old Dec 6, 2007 | 05:49 AM
07JKX's Avatar
i noticed a bit of the "bump steering"... granted... i think it depends on the quality of rubber you stick on your rig... b/c i picked up 5 no namers for a great deal 285/65R16... (450 installed)
i also think my stock stabilizer is bent... so i guess any well known aftermarket with be good to go??
Old Dec 6, 2007 | 12:02 PM
Mini-me's Avatar
Post Tie rod
Rock Krawler has a drag link and tie rod available and they come use 3/4 ton tie rod ends. I have not seen it up close. My local dealer has it on his JK so I plan to take a look at up close it in the near future.
Old Dec 6, 2007 | 02:34 PM
red5's Avatar
Default Guess you never rode over PA roads!!!
Guess you never rode on PA Roads
WORST ROADS
1. Arkansas
2. Louisiana
3. Michigan
4. Pennsylvania
5. Illinois
BEST ROADS
1. Texas
2. Florida
3. Tennessee
4. Georgia
5. Nebraska
When I went to camp jeep only then did I realize the trackbar was a bit lose those roads where like glass compared to PA. In PA the roads are so bad I just couldn't tell. The Jeep was never "smooth" long enough to feel the harmonic imbalance. You get up to 70 and at that speed you hit real bumps & ruts every 5-10 seconds.
If you Don't have a large steering stabilizer in PA you will wish you did! when I make adjustments it's tough to tell if it's the road causing the "problem" or the adjustment you just don't have enough "room" to "feel" it out.
Old Oct 15, 2008 | 12:40 PM
Rancho's Avatar
Sponsoring Manufacturer
Originally Posted by Zak
I am looking into replacing my steering stabilizer but not sure which one to get
Superlift Superride
Skyjacker Heavy Duty
Rancho ?? do you have the exact part number Quadratec are selling as universal not for JK also from what i know is there as clearence issue any the stock one is pretty thin compared to aftermarkets one >>>>>>>>>
Yep, our steering stabilizer unit is RS5407. The bracket kit that you will need to install it is RS5510. Just order both and its simple to install.
Old Oct 15, 2008 | 12:45 PM
bodybrdng's Avatar
I put the part numbers on Quadratecs site and it can not find them Found RS5510 but shows no pic or anything just price. http://www.quadratec.com/products/16028_900.htm
Old Oct 15, 2008 | 02:25 PM
DeepSky's Avatar
Where can you buy the Superlift SS stabilizer? Does it come with the bracket to attach to the axel?
Old Oct 29, 2011 | 09:46 AM
miramontes's Avatar
Thanks for posting this I just purshased the steering stabilizer from 4wd.com but they did not say I also needed the brackdet. On the Quadrtech site it does give you the option of adding it.
Chris Miramontes
Old Oct 29, 2011 | 09:48 AM
ChryslerChris's Avatar
Originally Posted by fishit
On another thread someone recommended a beefier steering stabilizer. I didn't want to highjack the thread since it was only a side note. What is a steering stabilizer? What are the benefits?
Thanks
Your avatar of Janet Reno really creeps me out!
Old Oct 29, 2011 | 01:47 PM
irishslim69's Avatar
I agree with everyone. Beefier stabilizer for bigger tires is definitely the way to go. I am running the Skyjacker Dual Kit. It's great. Relocates the stabilizers to the top of the steering linkage and definitely stiffens the steering. Easily installed and reasonably priced. Quadratec offers it. Check it out.
Old Oct 29, 2011 | 02:36 PM
Battlefrog's Avatar
I've ran the TF 9550 SS and was very happy with it ($62), but bent the crap out of it (kept me from falling in a 3' hole). I have now switched to a bilstein HD because it has a much smaller housing and better tucked away ($90)...
