Steering stabilizer
Old Aug 30, 2013 | 07:01 AM
Flexer07's Avatar
Thanks guys. I wasn't for sure. I would hate to get the lift put on and not be able to drive it because its my DD
Old Aug 30, 2013 | 08:12 AM
Punisher417's Avatar
Don't mean to high jack your thread, but my jeep tends to wonder on the road n progresses more as the speeds go up. It's not to the point where I can't drive it, it's still very drivable but for long trips might get tiring. I looked under the jeep n noticed that my stock steering stabilizer is bent. So I'm also looking into replacing it. Not sure if to go with a factory one or aftermarket. It's a rubicon on a 3" evo enforcer
Old Aug 30, 2013 | 08:20 AM
JKphotoshoot's Avatar
If everything goes on right and the steering is properly set up you don't even need a stabilizer.
I didn't run one for almost a year with 37 mud grapplers. Never could tell a difference.
Now I'm running hydro assist.
Old Aug 30, 2013 | 09:06 AM
Mark Doiron's Avatar
Did you install the lift yourself? A shop? What is the caster set to and how was it set? I'd look into that first.
As for the SS, if it's bent I'd pull it and drive without, or just replace with a reasonable brand (including OEM) that you can buy cheapest. No need to spend lots of money. But, as I wrote before: The TF (and some other aftermarkets) are built much stronger than the OEM and won't bend as easily. Just don't spend a bunch of money on some fancy set-up.
Old Aug 30, 2013 | 09:14 AM
Yellowfin's Avatar
I was about to say....the only thing you need to upgrade it to is hydro assist. Otherwise, keep the stocker, or take it off altogether. If you damage it, pick up either another stock unit, or something similar. It really doesn't do much anyway. I'm running the TF myself because I got a deal on it. Doesn't really seem to be too much bigger than stock.
Old Aug 30, 2013 | 09:52 AM
No off road evolution installed it a few months ago with the evo steering flip kit as well. Idk what the caster is set to. It drove perfectly great before I noticed it was bent.
Old Aug 30, 2013 | 10:55 AM
DesolationMania's Avatar
I tend to agree with where Mark was going. You may notice difficulty turning one way or another with a bent SS, but it won't cause it to wander. However, you caster settings can certainly make the steering more "flighty". If you bent the SS, take a good look at the tie rod as well. If it is frowning, even a little, then you've got too much toe in, which would cause more of a shimmy, which may in turn feel like a wander.
