Steering stabilizer bracket...
Old Jan 6, 2011 | 10:27 AM
Jusaplaya's Avatar
Default Steering stabilizer bracket...
Where do I get the steering stabilizer bracket that goes to the tie rod. I threw the other one away. I ordered a procomp bracket but it doesn't seem to be what I need. Any help would be appreciated. Be nice if I could get it at auto parts shop.
Old Jan 6, 2011 | 01:54 PM
Jusaplaya's Avatar
I found a clamp on quadratch that should work, but now I need a bolt to go thru axle side of steering damper mount. What size bolt is that? Is it 18mm? Any help would be appreciated.
Old Jan 6, 2011 | 02:18 PM
Hellbound13's Avatar
I believe its 19MM but Im not 100% on that.
Old Jan 6, 2011 | 02:43 PM
Jusaplaya's Avatar
Northridge 4x4 is showing a 15mm bolt and 18mm nut. That don't make much sense to me. Shouldn't these be the same size. Dirtman I am not following real good. Do you mean a 19mm nut and a 14mm bolt?
I got a billstein 5100 steering damper today.
I should be able to get these bolts at lowes? Should I get grade 8?
