Steering stabilizer install question
Old May 17, 2021 | 08:30 AM
microsup's Avatar
Question Steering stabilizer install question
Hello everyone.
I am replacing my old warn steering stabilizer with new one. I ordered a Falcon EF 2.1, after long time wait (backorder) finally received it, and to my surprise I realized that I ordered a wrong one. I thought that my tie rod from metalcoak is 1 5/8 but it ended up that it is actually a 1 3/8
So I can obviously return it and wait for correct size, now the stabilizer is out of stock again, and I need to pay shipping , so wasting at least 20 bucks.
So my idea is to use shims with 1 5/8 clamp to reduce size to 1 3/8 . Do you think it is a bad idea to use shims?
I found PVC pipe which ID 1 3/8 and OD is 1 5/8 which is a perfect size reducer, but will it work and not slip? should I search for metal shim or make my own from sheet of brass?
Any ideas suggestions would be greatly appreciated.
Old May 17, 2021 | 10:23 AM
resharp001's Avatar
Loved
Community Favorite
This is where everyone will chime in and say there's no need to spend so much money on a steering stabilizer outside of general "bling". I'd return it and either get the right thing if you're dead set on it, or just get a cheap SS which is all you need if anything. That is a lot of money that could be put towards a better upgrade.
If you are hell bent on that model, I'm just not a fan of tyring to pound a square peg into a round hole. You spent a lot of money, don't try to cheap out and make it work with a bandaid fix.
Old May 17, 2021 | 10:28 AM
microsup's Avatar
Yeah, this is what I think, maybe return it and wait for the right one. I like how firm it is, I need to apply all my weight to move it, compare with my old one I can pull/push it with very small effort.
Is the cheap one will provide same firm resistance?
Old May 17, 2021 | 12:36 PM
nthinuf's Avatar
Is there an issue with your steering that you are trying to add a bandaid to? (Like low caster after a lift that causes a loose/flighty feeling.)
Old May 17, 2021 | 12:55 PM
microsup's Avatar
No, no issue, I just ordered a new SS and I ordered a wrong clamp size. My tie rod is 1 3/8" , but I ordered for size 1 5/8. So I can't install it without shim. That's why I was asking what if I put a size reducer.
And yes my steering is kind of very light, and sometimes at speed 40-50 I fill little vibration on a steering wheel. With new SS I think my steering will be not so light and responses from road surface will be less.
I installed new TF ball joints, and tie rod and drag link from Metalcloak. No lift. Also I replaced a steering box with new one. and new wheels and 33" tires.
Old May 17, 2021 | 08:00 PM
Sv_dude's Avatar
5 Year Member
Loved
Community Favorite
You can call metalcloak and order the larger tie rod. The tie rod ends are the same so you can buy just the tie rod... I would do that before you try to shim anything. Their new tie rods are 1 5/8”.
Old May 18, 2021 | 04:06 AM
resharp001's Avatar
Loved
Community Favorite
How old is that TR? I don't recall MC making a 1 3/8" TR. I believe the factory TR is 1 3/8" which is probably why TF offers that, but pretty much all aftermarket TRs should be 1 5/8" or larger. Bit perplexed by this situation.
It does seem like you've thrown a lot of parts at the steering, so it makes sense now why you were trying to step up on the SS. Usually feedback that is in a certain speed range leads back to tires. Have you tried swapping the rear tires to front to see if that changes any? It's not normal to get that feedback and though adding that SS might help disguise it, it seems something is a bit off which is causing the feedback to start with.
Old May 18, 2021 | 05:37 AM
Sv_dude's Avatar
5 Year Member
Loved
Community Favorite
At some point last year metalcloak started using 1 5/8 tie rods for the jk. When I talked to them after I bent my tie rod, they said that the started using 1 5/8 for the JL’s and then just decided to use their JL tie rod for the jk.
Old May 18, 2021 | 05:53 AM
microsup's Avatar
My tie rod is pretty much new I bought it maybe year and a half ago, so don't want to replace just normal working part. I was thinking that why would I shim it if I can just replace it with a correct size. I was waiting long enough to get it so I can wait a little more and got the right one. So I swallowed $20 shipping cost and sent it back for replacement.
Thanks for all advises, I will try to put back wheels to front to see if it is any difference, also I may go to check wheel balance to see if it will be any improvements.
Old May 18, 2021 | 06:01 AM
resharp001's Avatar
Loved
Community Favorite
Been a long time since I shopped TR's. I must just have the numbers mixed up in my head. 1 3/8" sounds so wimpy.
