Steering Stabilizer installation
Old Aug 25, 2010 | 12:17 PM
gerdyj's Avatar
Default Steering Stabilizer installation
Old Aug 25, 2010 | 12:33 PM
Jeepjk09's Avatar
Default What about them?
I put a set of skyjacker dual's on my 09 2 door. Had the 4" sky jacker lift on it but she liked to pull hard when I hit bumps.......Easy to put on.....
Old Aug 25, 2010 | 12:42 PM
jwind's Avatar
Extremely easy to put on. Excellent directions come with the kit. Just make sure you can cut off your stock stabilizer bracket to get it out of the way of the mid mounting plate. I have 35's and it makes a world of difference.
Old Aug 25, 2010 | 12:56 PM
gerdyj's Avatar
Not planning on a dual setup or anything, just replacing the one I have now. I'll still be using my OE brackets. It looks pretty simple, but I've never actually done this either.
Old Aug 25, 2010 | 01:01 PM
Drsalee's Avatar
Tag for future reference.
Old Aug 25, 2010 | 01:20 PM
Alec's Avatar
Replacing the OE stabilizer using OE brackets:
Unbolt one side of shock
unbolt the other side of shock
reverse process with new shock
I understand hesitation 'cause we were all there once, but if you can't do this "project", are you capable of pumping gas into the Jeep?
EDIT: ok, ok, I'll bite again. A direct replacement should be exactly the same length and stroke of the stocker. However, if it's not, you need to make sure you have enough stroke to either side for full steering lock. After installation, have someone steer from side to side to check this. If not, adjust the moveable bracket either way until you have what you need.
Old Aug 25, 2010 | 01:34 PM
gerdyj's Avatar
I'm sure it's easy enough, but sometimes the simplest things can turn out to be a huge pain in the ass.
Old Aug 25, 2010 | 02:09 PM
TeraFlex's Avatar
Sponsoring Manufacturer
I have installation guide if you need. Just need a email address for anyone here that wants it.
Old Aug 25, 2010 | 04:05 PM
gerdyj's Avatar
Thumbs up
Originally Posted by toad
Thanks for that link, it was very helpful.
Old Aug 25, 2010 | 04:53 PM
RyanBlack321's Avatar
I replaced my stock stabilizer with a Bilstein Steering Stabilizer and it made a huge difference.... I have these shocks all the way around as well, I am very impressed.
