Steering Stabilizer Relocation Brackets
I am torn between the JKS steering stabilizer relocation bracket and the Dominion relocation bracket. Do any of you have either of these products and how do you like them? Which one do you favor? I do not plan on welding the JKS bracket also, so im looking solely at where the stabilizer is relocated and if i need anything else other than the bracket (i was looking at another relocation bracket and it required 1 3/4 bump stops in the front to keep the stabilizer from hitting the frame when the suspension contracted). I have a teraflex 9550 steering stabilizer BTW which i will be using on this bracket. Post pics if you have them also!
Here are the product links:
JKS: http://www.quadratec.com/products/16007_0102.htm
Dominion: http://ok4wd.com/dominion-offroad-je...__store=okauto
I think my JKS bracket is sick! It relocated the steering stabilizer, it can rise where the trackbar mounts, and gussets the upper control arm mount on that side. I did the draglink flip at the same time, which was easy, with the raised trackbar they work well together. Drives amazing!
I went with this JKS Bracket
http://www.northridge4x4.com/proddet...rod=JKS-OGS162
Got it as part of this kit on the recommendation from Dave at Northbridge. Also reinforces the track bar mount on the axle
http://www.northridge4x4.com/proddet...KS-OGS162COMBO
