Steering Stabilizer Relocation Kit
Old Mar 29, 2013 | 10:35 AM
Monte417's Avatar
Default Steering Stabilizer Relocation Kit
Ok guys my steering stabilizer is mashed up pretty good so I need to replace it. Im looking for a kit that will include a relocation bracket on the trackbar, a bracket on the tie rod and the stabilizer. I know jks has the trackbar relocation bracket and a tie rod bracket but no stabilizer and also requires welding which im not into doing. Any kits out there that include all 3 components?
Old Mar 29, 2013 | 11:24 AM
ronin2120's Avatar
Vet Army
The new Fox ATS comes with everything. It mounts above the tie rod and uses a longer bolt to mount through the drag link. It's a bit pricey about $300 but its complete and all bolt on.
Old Mar 30, 2013 | 12:52 AM
101gargoyles's Avatar
Former Member
Old man Emu.
Got mine from Northridge $124 shipped free in Canada. Probably less costly your end.
Complete kit and also mounts above tie rod. Uses rubber boot to help protect the rod from stone chips which is the main cause of shock/stabilizer failure.
All bolt on as well.
Old Mar 30, 2013 | 02:35 AM
ilikeguns's Avatar
Originally Posted by 101gargoyles
Old man Emu.
I have this one and really like it, however it sounds like the OP is looking to replace the OEM bracket on the tie rod which the OME kit doesn't include.
Old Mar 30, 2013 | 05:15 AM
JohnnyQuik's Avatar
The JKS bracket doesn't require welding. It can be bolted on if you don't care about reinforcing your trackbar mount. Just order the JKS and any stabilizer with 5/8 mounting eyes and you'll be fine.
Old Mar 30, 2013 | 05:31 AM
smittycm's Avatar
Veteran: Marine Corp
I'll plug Jeepswag.com here. Ordered the Dominion Offroad bracket and it showed up in a couple days. Only $35 dollars. Hard to beat. It was an easy install and it works perfectly.
Old Mar 30, 2013 | 06:48 AM
Grand Umpah's Avatar
x2 on the Dominion product from Jeepswag.
Bracket and stabilizer for $99.
Have to drill a hole, but that the only step requiring any effort.
Old Mar 30, 2013 | 06:58 AM
4fox's Avatar
I picked up a BDS SS from a local shop and it included the relocation bracket. I think the price was about $50
Old Mar 30, 2013 | 11:33 AM
Monte417's Avatar
Thanks for the replies guys. It turns out his does offer a kit with the track at bracket, tie rod bracket and stabilizer for like 150 at northridge. Didn't think they made a stabilizer has anyone ever used it. How about the synergy one
Old Mar 30, 2013 | 06:42 PM
lowendrider's Avatar
I went with the dominion offroad bracket myself. I knew from reading posts here that it would work with the factory ss which I have still in good shape. Just a thought...how much are oem stabilizers? They seem to work just fine and if cheap enough you could pick up one of those, the bracker, flip the tierod bracket, and you'd be good to go.
