Steering Stabilizer Upgrade and Lack of a Turning Radius
Old Jul 5, 2010 | 08:52 AM
1230frstap's Avatar
Former Member
Default Steering Stabilizer Upgrade and Lack of a Turning Radius
Hey All,
I took out the OEM steering stabilizer and replaced it with a Teraflex steering stabilizer yesterday. All seemed fine until I tried turning the Jeep to the right...the turning radius has been virtually cut in half!
However, when I turn it to the left, all seems fine.
My guess is that I need to adjust the bracket that the steering stabilizer attaches to near the front diff. If so, which way should I move it? To the left or right? And, how far should I move it?
Sorry if this is a Noobie question...I have been searching since yesterday and can't find anything.
Thanks all and happy 4th!
Old Jul 5, 2010 | 09:03 AM
FlameRed's Avatar
Something isn't adjusted right, the steering stabalizer should not be the limiting factor.
Loosen evertthing up, turn all the way to the left, and tighen the stabilizer so there is about 1/8" of the shaft showing.
If you're not able to turn right you need to move the tie rod attachment towards the passenger side.
Old Jul 5, 2010 | 04:19 PM
1230frstap's Avatar
Former Member
Thanks for the responses...going to try to fix it tomorrow
Old Jul 8, 2010 | 02:07 PM
1230frstap's Avatar
Former Member
Default an update
I finally got a chance to take a look at it again and I am not sure of what to make of what I found. When I turn the steering to the right, it stops with about 2" still showing on the steering stabilizer shaft, severely limiting the turning radius. And, the kicker is, it starts to leak fluid from the stabilizer shock when it is left in this position.
The Teraflex shock is longer than the OEM steering stabilizer, and I think that the angle that is created when I turn the Jeep to the right stresses the dampener shaft, causing it to get pushed to the side and allowing fluid to leak out.
I do not think that adjusting the bracket will do anything, as the angle will still not be right for the dampener shaft to move freely from the left to the right.
Do I need a steering stabilizer relocation bracket, or have guys put the Teraflex on the factory set-up without any problems?
Thanks for the help
Old Jul 8, 2010 | 02:10 PM
1230frstap's Avatar
Former Member
Do you guys think this is the result of a bent tie-rod?
Old Jul 8, 2010 | 02:30 PM
rinkishJK's Avatar
well i have the same shock and a woods relocate bracket and i dont have any issues. maybe u should pickup the bracket, and solve 2 issues. 1. the stock one hanging down low in harms way, and 2.... your issue!!! its not alot of $$$ and well worth it.
Old Jul 8, 2010 | 02:48 PM
1230frstap's Avatar
Former Member
Sounds like a Woods relocation bracket it is
Old Jul 8, 2010 | 02:54 PM
1230frstap's Avatar
Former Member
Does anyone have the link for the Woods relocation bracket?
Old Jul 8, 2010 | 03:03 PM
rinkishJK's Avatar
Default Re: Steering Stabilizer Upgrade and Lack of a Turning Radius
He is a sponsor here. Look in the sponsor area. Jeepswag. I am on phone and don't know hhow to post link.
edit... its www.jeepswag.com
Sent from my Droid
Old Jul 8, 2010 | 03:19 PM
1230frstap's Avatar
Former Member
Sent from my Droid
THANKS! I'm on it!
