Steering stabilizers
I have a 2008 JK and have added 33" Tires and a 2.5" coil spring spacer lift. I am going to put a steering stabilizer on but not sure which one. There are so many to choose from. Any suggestions from experience? Should I get new shocks at the same time?
Thanks,
Thanks,
if your stock steering stabilizer isn't bad, just stick with it. there is no need to replace it if it's not damaged.
as far as shocks go, if you didn't install shock extensions with your lift, yes, having new longer shocks is something you should get as they will allow among other things, more suspension travel.
The Rancho stabilizer part number RS5407.
The mounting kit is part number RS5510.
As with all of our products comes with a limited lifetime warranty.
It is often best to upgrade when you get into larger tires (35"+), but not always necessary as wayoflife mentioned.
Good luck in your choice.
I got the terraflex stabilizer and i did not take away the shimmy in the steering wheel. For all of you who are happy with the results given by a stabilizer did it take away the wobble?
