Steering upgrade options
I've recently added 35's to my 2dr rubi and since then I've noticed that the steering itself is not quite as stiff as it used to be and find it a bit too easy for the wheels themselves to react based on bumps in the road. It feels like when I broke the stock stabilizer, and since then I've got Tera's steering stabilizer on there which has worked great up until I put on the 35's. I'm wondering what options there are to stiffen this up a bit more and get it closer to stock feeling....
what psi are you running in your tires?
which lift do you have? (how did you adjust your caster?) what is your caster currently set at? |
Around 30 psi, OME long travel (probably a touch over 3") and unclear on the caster angle, but haven't noticed any flighty steering that would cause me to think it's out of whack, but something I can probably check...
find it a bit too easy for the wheels themselves to react based on bumps in the road. |
Yeah, it's something I definitely need to check to be sure...but I'm noticing it at offroad speeds too, it just exacerbates a bit more at higher speeds on the road.
It's all about the geometry really. You've changed things from stock and the only way to get the stock feel back is to correct what you have changed. On a side note, 35's are gonna make your jeep handle differently regardless, theirs alot more tire making contact with the road so you'll get more road feel. Your describing loose steering right? Playing with your caster angle should help that. The only other thing I can think of for loose steering is play in your steering box. I've heard of a number of jk's with steering box problems while running bigger tires, might wanna check that out. Before I go farther what do you mean exactly by the wheels reacting to the road? Are you getting bump steer or steering wheel shimmy?
Although there customer service is subpar, the RE drag link flip made my steering control significantly better. I had the steering clunk for 2 years and it is now barley noticeable. The steering is also significantly stiffer due to the tighter ball joints and there is less bump steer as the drag link is almost parallel with the road.
I am using the drag link flip with a dropped pitman arm. |
I put a Teraflex drag link flip kit on and really tightened up the front end. I also installed the Rockcrawler tie rod and have really beat on it in the rocks and it has not bent yet.
Chris |
I also am running a beefier tie rod and drag link. They have 1 ton ends also that are greaseable. Made the front end much tighter. The stock tie rod and drag link is crap if you ask me.
Thanks for the info here all :thumbs:
