Steering wheel
Old Sep 15, 2010 | 03:51 AM
cdryanhall's Avatar
Default Steering wheel
I seen it once but now i can't found it now can someone help i need the write up how to get the steering wheel back inline after a lift thanks for the help
Old Sep 15, 2010 | 04:08 AM
RyanBlack321's Avatar
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Sep 15, 2010 | 04:27 AM
JulianK's Avatar
The picture shows that you can turn the turnbuckle by hand but that's not always the case. I had to get vicegrips on it but it worked perfectly and that was over a year ago!
Old Sep 15, 2010 | 06:01 AM
wayoflife's Avatar
JK-Forum Founder
if you spray some pb blaster, kroil, liquid wrench or the like and then tap around the turnbuckle with a hammer, i think you will find that it'll be much easier to turn.
Old Sep 15, 2010 | 06:51 AM
cdryanhall's Avatar
Thanks for the help
Old Sep 15, 2010 | 10:18 AM
bobbyspaghetti's Avatar
Default yup
Mine was hard to adjust past a 1/4 turn when I did mine after the lift and the threads looked super clean. But as usual I am going to say WOL is right there must be dirt/dust/crud whatever in the turnbuckle because I WD-40'd as much as I could on it and turned it clock wise and ccw a few times and away she went. I used a pipe wrench to turn mine but I'm a gas plant operator so I use a pipe wrench for everything. Good luck.
