Steering Wheel Off Center
Old May 8, 2009 | 03:10 PM
PatAck's Avatar
Default Steering Wheel Off Center
Went off roading today... afterwords i noticed my steering wheel is now off center. Nothing looks bent... i also used the search function but didnt find anything useful.
Any ideas?
Old May 8, 2009 | 03:26 PM
greenamphibious's Avatar
http://project-jk.com/jeep-jk-write-...-end-alignment
Old May 8, 2009 | 04:08 PM
PatAck's Avatar
Is it normal for the steering wheel to get off center after going off roading?
Old May 8, 2009 | 05:12 PM
nthinuf's Avatar
Yep, lots of folks saying the same thing. Even though nothing looks bent, it's a good bet that something is. Tie rod, 'C', hard to tell unless you really know what you're looking for I guess. (mine is off from an offroad trip also, and I don't see what is bent either...)
Old May 8, 2009 | 06:16 PM
NH4X4's Avatar
Mine did the same thing, check your steering stabilizer, mine had moved and was pulling the wheel just a little to the right. I re-centered the SS and the wheel was straight again. Check the stabilizer
Old May 8, 2009 | 06:33 PM
STUPIDFACE's Avatar
Yeah, i also noticed that my steering wheel is off a little after off roading. I looked underneath and nothing looks bent. I even compared it to another jeep. I never looked closely at the steering stabilizer though. Ill check it out tomorrow. I dont undrstand how it would pull the steering.
corey d
Old May 8, 2009 | 06:52 PM
rjhoop's Avatar
you can bring it by my house if ya want to compare things!!!!NEVER MIND THAT DIDNT COME OUT RIGHT!!!!!hey where in buffalo??
Old May 8, 2009 | 07:13 PM
PatAck's Avatar
My steering stabilizer is bent, i just got a new one yesterday (didn't put it on yet). I don't really see how that would make the steering wheel turn...
rjhoop, im in north tonawanda
Old May 9, 2009 | 08:21 AM
PatAck's Avatar
When i was going to pick up my steering stabilizer from work my ESP light came on and now it wont go off...
Im going to put the new stabilizer on and center my steering wheel... any other tips/tricks i should know about?
Old May 9, 2009 | 08:29 AM
0311sgt's Avatar
I am bettting that your tie rod is bent. If your ESP ligt came on after an offroad trip, and your wheel is off center too...most likely the tie rod. Have the code read at your local Advance Auto center and I will bet it is an "alignment code" Has happened to me 2 times now. Last time was at JK fest. Drove 2 days with a bent tie rod and ESP light... put on a new tierod in the parking lot (thanks to River Raider) and the esp light went off on the way home. It doesnt take much for that FLIMSY thing to bend. Good luck.
- 07 JK Unlimited X
- 3” BDS suspension lift
- 33x11.5x16 tires soon to be 35x12.5x16
- JKS Quicker Disconnects
- Warrior Products Tube Doors Rear
- Mopar OffRoad Rear Bumper
- SkidRow Oil Pan/ Tranny Skid Plate
- RoundStar OffRoad Custom Front Winch Bumper
- Skyjacker Adjustable Rear Track Bar
- Skyjacker Brake Line Extenders
- Rock Krawler High Clearance Adjustable Front Lower Control Arms
- Rock Krawler Heavy Duty lower control arm brackets w/ skid plates..thanks to Eric at Skid Row for welding them on for us.
