Steering wheel wobble/bump steer
Well I finally got under the jeep today and checked things out - made sure the shocks were tight and the track bar was tight. The upper nuts on the front shocks weren't very tight, the right side was really bad. I could move the shock by hand, so loosened the R/F and tightened it back up. It seemed like everything was back to normal on the ride home. I felt a ton better, and the "bump-steer" and wheel wobble issues didn't happen at all
I do have one question about OME shocks to make sure i have everything in right order. Does it bolt up this way -> shock-large washer-bushing-washer with the little lip on it-?shock tower on jeep?-bushing-washer-and then the nut?
Dumb question I guess, but I just want to make sure I'm not missing anything.
The front end issues are comulative. I had what I'd call bump steer (hit a bump, the steering wheel bounced back and forth). this was worse at certain speeds, and at certain turning angles (around 40mph and turning slightly left). There was a bump at my on-ramp that always caused it to happen.
As the problem got worse, it would sometimes cause death wobble, which WAS VERY distinctive.
Here's what finally fixed it (in the order I did it, which wasn't correct):
- The situation was very sensitive to tires being balanced.
- The situation was very sensitive to the Toe setting on my alignment. The moment it was off, the situation got much worse. (it got knocked out after every wheeling trip)
- Steering stabilizer was worn, so I replaced it. This helped (or really just masked it) fro a while.
- I installed lower control arms to dial in 6.5* of caster, and,
- I installed a front adjustable track bar to center the axle.
- All 4 ball joints were replaced (under warranty
), which took care of a lot of the problem.
Then finally, the final fix:
- I installed a new, BEEFY Teraflex tie rod to replace my bent one.
In hind sight, I should have replaced the bent tie rod before even replacing the LCA's or even the track bar. I didn't realize how bent it was.
LESSON: You first need to fix anything that's not within specs (bent, worn, etc). Then you need to replace/upgrade parts like LCA's to get more caster.
), which took care of a lot of the problem.Then finally, the final fix:
That's what mine was doing, the wheel wobble thing. I checked my ball joints and I think they're ok. I looked up a few ways of checking them and that's what I did right after tightening the shock. I also checked my track bar for worn holes and it was fine. LCA's would be nice I guess, but my jeep doesn't feel "flighty". I had zero problems until I changed the shocks, and I found my LF axle seal was leaking at the same time, which when i think about it, it may have just been overfilled. I'm not sure why or how a loose shock could have caused my steering problem, but it hasn't happened since I tightened it.
Well. I thought I had the problem fixed, but I guess it's not completely fixed after all. I still notice what I would consider "bump-steer" when I hit some bumps. My wheel doesn't violently shake a half turn or anything, but it does shake about... ?? 10 - 2 ?? quickly a few times. I've checked the steering components and everything seems fine. Could it be the steering stabilizer is bad and isn't absorbing the shock of these bumps? When I say bumps I'm not talking about large potholes, but more like an area of the road that has cracked and swollen a little all the way across the road. It seems if i hit them just right, my wheel shakes.
I'm wondering how many people with bump steer have swapped wheels with ones with less back spacing? I understand that this can amplify bump steer due to the increased leverage away from the steering axis.
I don't know??? I didn't have any issues at all until I changed shocks. When I get back to Indiana I think I'm putting the RC shocks back on and I'll see if I still have the problem. The shocks shouldn't have caused any of this, but it was only after I changed them that I had this happen.
A loose shock can definitely cause it... Soon after buying my jeep I had a noise coming from front right wheel....at first it was just annoying. It then became death wobble. The top shock bushing had disappeared. Dealer replaced it and it never happened again.
Sent from my DROIDX using Tapatalk
I had a similar problem with an LJ Rubicon. When I installed softer shocks, it went from steering wheel wobble/front end shimmy to full blown death wobble. In my case the problem ended up being a trackbar issue. Somehow the softer shocks seemed to amplify the problem, but they didn't cause the problem. Once the trackbar issue was addressed, it drove fine.
