Still hearing it.
Old Jan 1, 2013 | 11:43 AM
Biglew81's Avatar
Default Still hearing it.
I've got a 2012 Jk 2 door 3 inch lift and every time I drive it around corners, there's something popping or shifting and causing a thump or pop coming from the back end it has a 3 inch coil lift track bar relocation bracket new shocks and springs new sway bar end links. I can't find out where the noise is coming from except its in the rear end please help.
Old Jan 1, 2013 | 12:57 PM
Twinkydog's Avatar
Do you have anything in your storage bin in the back? I keep my receiver hitch, hitch pin, and strap in mine. Every time I turn a corner the receiver or pin makes a noise like you are describing.
Old Jan 1, 2013 | 01:03 PM
Biglew81's Avatar
Yeah it's actually full of stuff. Reciever, winch remote, straps etc. but I just recently started hearing it and the bin has been full for months.
Old Jan 1, 2013 | 03:52 PM
wraff's Avatar
Check your trac bar bracket bolts. Mine loosened up. I tightened them up and added thread locker. It lasted for a few months, now its loose again. I'm not sure what the next step would be.....
Old Jan 1, 2013 | 05:20 PM
Canibeat's Avatar
Weld it...
Old Jan 1, 2013 | 05:26 PM
familytime's Avatar
JK Forum Regional Rep
On the passenger side rear,check to see if your coil is making contact with track bar on frame,also check your sway bar link,they may be catching your brake line(hard line)
Old Jan 1, 2013 | 05:27 PM
Woody's Avatar
Vet Army
Springs set in indexing location. Don't ask how I know this !! Cheers
Old Jan 1, 2013 | 05:48 PM
Biglew81's Avatar
Indexing location ?
Old Jan 1, 2013 | 05:51 PM
Willis19's Avatar
Originally Posted by Biglew81
Indexing location ?
I had this problem to I tightened my track bar bolts and it solved the problem. Goodluck!!
Old Jan 1, 2013 | 05:58 PM
Canibeat's Avatar
Indexing location ?
It's a lip/notch on the axle that the springs sit in...
Check U joints for play.
