Stock Gears
Old Aug 6, 2010 | 08:52 AM
leaky10's Avatar
Default Stock Gears
Just bought a 07 X a couple weeks ago. It has 35" with a BB Lift installed. Trying to figure out if the previous owner re-geared? any suggestions?
It doesn't seem down on power but it's my first Jeep so not really sure what stock feels like. Live in a small town so haven't had a lot of time at higher speeds.
Thanks
Old Aug 6, 2010 | 09:08 AM
nthinuf's Avatar
This is from a 'what are my stock gears' thread, but...
Window sticker if you still have it.
Send in the VIN and have them send you a new build sheet.
Measure your tires, (actual measured height, not mfg's spec) take a drive and see what your rpm's are at 70, then check the charts in the Drivetrain Faq's
From Ronjenx:
Chock the front tires, fore and aft.
Put the transmission in neutral.
Emergency brake off.
Jack the left rear tire off the ground.
Put a jack stand under the frame, just in case the jack fails (had to add this).
Put an index mark on the aft end of the drive shaft, visible from the left rear wheel.
Put an index mark on the left rear tire at the 6 o'clock position.
Rotate the left rear tire 2 complete revolutions while counting how many times the index mark on the drive shaft passes its original position.
That number will be your axle ratio.
Remove jackstand and lower jack.
Put transmission in gear and/or apply emergency brake.
Remove chocks.
If you have limited slip, jack up both rear wheels and rotate one revolution, making sure both tires rotate equally.
If the driveshaft rotated almost 3 1/4 turns, you have 3.21
If the driveshaft rotated almost 3 3/4 turns, you have 3.73
If the driveshaft rotated a little over 4 turns, you have 4.10
Same with 4.88, 5.13 and 5.38. Just count the approximate rotations.
Old Aug 7, 2010 | 12:17 PM
dpoelstra's Avatar
with 35's? Is it what you would call peppy and has good power? Or would you consider it a dog? the dog is not re-geared.
Take a look at the diff cover. does it look like it has been wrenched on?
Old Aug 12, 2010 | 08:56 AM
leaky10's Avatar
I cannot find the drivetrain FAQ link anywhere. I finally got out on the highway and up to 70 to check my rpm's and was looking for the chart.
Old Aug 12, 2010 | 09:10 AM
nthinuf's Avatar
Stickied right at the top of this Modified area. If it was a snake...
Old Aug 12, 2010 | 10:33 AM
leaky10's Avatar
I found it, and know believe i should sell my jeep and ride the short bus to work! Thanks!
