Stock gears?
Old Nov 2, 2012 | 04:37 AM
856kid's Avatar
Default Stock gears?
I have a 2008 jku Sahara. I do I find out what gear ratio I have?
Old Nov 2, 2012 | 06:02 AM
TCJK11's Avatar
On your build sheet. You either have 3.21, 3.73 or 4.10.
Old Nov 2, 2012 | 08:09 AM
blue project's Avatar
Not always but most likely, auto trans you have 3.73, standard you have 3.21 and Rubicon 4.10
Old Nov 2, 2012 | 08:39 AM
ronjenx's Avatar
Your automatic transmission would have come with 3.73 gears in the axles.
But you can always jack a tire, spin it two revolutions and count the drive shaft turns. That number will be your axle ratio.
Old Nov 2, 2012 | 08:46 AM
rays0852's Avatar
I have a 2012...not sure if they changed since earlier models, but my auto came standard with 3.21s.....3.73 and 4.10s are optional.
Old Nov 2, 2012 | 08:48 AM
ronjenx's Avatar
When they went to the 3.6/5 speed auto, the stock gear combinations changed.
Old Nov 2, 2012 | 09:18 AM
PatrickESJK's Avatar
I have the 3.73, which seems middle of the road. Is that a solid gear for motoring in the sand and mud with 35's on a 2.5 lift? I currently have 31 but havent made my mind up on the 33 or 35 inche tires.
Old Nov 2, 2012 | 11:12 AM
wvudave's Avatar
I have 35s on my jk with only 3.21 and its well under power im in the processes of going with 4.10 that should bring me back to stock hp...hopefully. but go with 35s!!!
Old Nov 2, 2012 | 04:09 PM
a4x4high's Avatar
I would go atleast 4.56 . I just went from 3.21 to 4.56 i am very happy with the rpm range it runs and power increase was really good . Eventually i am goin to super charge so i will have good rpm range and even more power . I have an 07 jku .
Old Nov 7, 2012 | 12:12 PM
wvudave's Avatar
Still trying to decide from 4.56 and 4.10...what kind of rpm range difference and gas mileage difference. Im getting 18mpg with my stock 3.21s
