Stock rubicon wheels
Old Oct 10, 2014 | 04:29 PM
Picachojeep's Avatar
Default Stock rubicon wheels
Does anyone know the wheel size and offset for the stock Rubicon rims? I want to see what the biggest tire is that I can put on without going to new rims. Also want to make sure tire don't rub.
Thanks
Old Oct 10, 2014 | 04:34 PM
tribulation138's Avatar
Thanks
I believe its 33's no rub. Someone correct me if im wrong
Old Oct 10, 2014 | 04:43 PM
nthinuf's Avatar
Stuck right to the top of this modified area is a thread with " FAQ's" in the title. You should find rim width and backspace info there.
Old Oct 10, 2014 | 04:55 PM
jdenney's Avatar
I wheel with a guy who has 37s on his 2011 5 spoke rubi wheels
Old Oct 11, 2014 | 03:18 AM
jadmt's Avatar
JK-Forum Ambassador
stock backspacing is 6.25" you can run 285/75-17 i.e. 34's if you remove your plastic air dam. very slight rubbing on front sway bar and close to rear driver side lower control arm. it is 7.5" wide and most tire manufacturers will spec what size rim their tires will go on.
Old Dec 5, 2014 | 11:29 AM
should I use 1.5" wheel spacers? I also have a 2.5" Rubicon Express suspension lift
Old Dec 5, 2014 | 03:57 PM
nthinuf's Avatar
Are the tires rubbing on something inside the wheel wells? If they are, and you want to move them out to prevent the rubbing, then yes...
