Stock track bar and BB?
Old Oct 19, 2014 | 09:01 AM
mr_alex2's Avatar
Default Stock track bar and BB?
Need some help...
Im in the process of installing a budget boost - terraflex. Shock extensions, on JKU 2012.
I removed the front track bar, only way I can see to get the springs in there. I can't get that mother effinh front bar back in! Help!!
Ideas? I saw the directions said to loosen only, but the springs didn't fit that way.
What are my options?
Thanks all!
Old Oct 19, 2014 | 09:09 AM
GreenJKBooger's Avatar
this might help? https://www.youtube.com/watch?v=ixC0OzIF5Go if it doesnt youtube have many vidoes there might be better one you just might need to find it .
Old Oct 19, 2014 | 09:45 AM
Baddkarmaracing's Avatar
Ratchet strap from the frame to the front end some where and put tension on it till it gets where you need it. If it's too far off you may need a new track bar or Atleast a relocation bracket
Old Oct 19, 2014 | 11:21 AM
Rebar-7's Avatar
Originally Posted by mr_alex2
Need some help...
Thanks all!
Try connecting frame side then turn your wheels left or right to line up to bracket on axle....
Old Oct 19, 2014 | 12:08 PM
Invest2m4's Avatar
I usually just have someone push from on side. Otherwise, I put a foot on the frame and push with my leg. It's pretty easy to move it around.
Old Oct 19, 2014 | 12:58 PM
mr_alex2's Avatar
Ratchet strap worked! I called a friend, it worked!
