Street Jeep checkin in!
Although it's a crap-shoot, if you bought someone's worn out, saggy factory coils, you'd likely get a drop. Find someone that had a big bumper and winch and towed. You could net a pretty significant drop.
Skyjacker makes a 2" front / 2.5" rear, lowering spring set. Part number is LOWJK024. A JK with body matched flares and hardtop, probably wouldn't look too bad, if it was done with the right wheels/tires.
Post some pics if you do it!
I wouldn't cut your springs. They are wound so the ends are flat and seat properly. If you cut them they will not sit properly and will make tons of creaking. They might even break somewhere along the cut coil from the uneven load. They will also probably wear a groove where the end of the spring rubs the seat.
