Stubby Stinger suggestions.
Have about 500-600 for a stubby stinger. Any thoughts on which way to go? After trying to look around it;s impossible to make up my mind from the 100 different types. Would like a stinger that sticks out above the hood.
If you have factory fog lights and want to retain them it could help narrow your choices.
If you want a winch that will also narrow your search.
Stubbies vary in coverage so that can be used as a decision point as well. (not all protect the entire grill)
Lastly, if you want a true bolt on that will cut the choices. (ie read the install pdfs)
Thank you for this info, i'm looking for more of a stinger. I like the winch set lower and fog lights.
I have the PSC BFH with the trail stinger - it's $375:http://shop.poisonspyder.com/JK-Fron...7-16-020-s.htm They also have a comp version - the stinger is bigger on the comp - it's $395:http://shop.poisonspyder.com/JK-Fron...7-16-020-c.htm
Shot from the driver's seat -I'm 6'3, so it might look different depending on how tall you are.
If you go this route, you have to do this to your frame rails:
JD
JD
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=237931"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=237932"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=237933"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=237934"/>
JD
JD
