Such a thing as a bushing kit?
Old Sep 29, 2012 | 05:14 AM
Theonekyle's Avatar
Default Such a thing as a bushing kit?
Hi everyone
I am sure it's somewhere in the forum asked before, I probably just can't find it. Looking at the Jeep today I noticed several of my bushings/bolts bad and are due replacement. Rather than hunt down individual bushings and bolt sizes are there any bushing kits or bolt kits available? Thanks for any help/advice!
Old Sep 29, 2012 | 06:52 AM
DEZ JK's Avatar
Energy suspension makes replacement suspension bushing
Old Sep 29, 2012 | 08:46 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
Originally Posted by Theonekyle
Hi everyone
Are you talking about the stock bushings? If so what makes you think they are bad?
Old Sep 29, 2012 | 09:07 AM
Delux2769's Avatar
There is a Grade 8 Bolt kit. Northridge 4x4 has one made up. Or you can go piece together your own, slightly more expensive this way.
For bushings, i don't know.
Old Sep 29, 2012 | 09:20 AM
blue project's Avatar
4wd.com has all the bushings in a set or separate from energy suspension.
Old Sep 29, 2012 | 12:10 PM
Theonekyle's Avatar
one front end link is jumping around the bolt and moving under suspension travel. my lower shock bushings are bad too. bolts are tight but I can wiggle the base of the shock around the bolt. and most others are all tight and good, but their getting that dryrot look to them. their all stock except for shocks, skyjacker (go figure). want to replace with polyurethane ones ideally, and new bolts to make sure it's all seamless . thanks for all the input everyone!
