Super Cheeser Modification for Free
On the rear tailgate, I was removing the third brake light wire and had to access the wire threw the little vent door. After removing the door I started thinking... there is 6 square inches of space!
So, I removed the little silver metal pins on the vent plastic door and now I have modified this door to easily be accessible for stuff. So, you can put your cocaine in there or towels in my case.
Once you remove the little silver metal pins, the door can be easily put on and off without tools.
A secret compartment or extra space for things.
[IMG]
[/IMG]
The dog wouldn't fit.
Once you remove the little silver metal pins, the door can be easily put on and off without tools. A secret compartment or extra space for things.
[IMG]
Looks like you just found the perfect location for the ammo chamber of a Bond-type device... cut out the matching section of sheetmetal on the other side, hinge it, and rig a push-button release system... Then, the next time you have someone tailgating you, flip your switch and let whatever you stuff in there fly out the back and onto their windshield! Just think of the possibilities!
