Super chips and aev procal
Old Apr 23, 2014 | 11:47 AM
zero_traction69's Avatar
Default Super chips and aev procal
Hey does anyone know if you can use super chips and the aev procal together? I have a tune on my jeep to get 93 octane, but I want to use the procal to turn off my sway bar light because I went anti rock front. Does anyone know if they will work or I risk blocking my ecu?
Old Apr 23, 2014 | 11:51 AM
nthinuf's Avatar
Yes, they work together fine.
Old Apr 23, 2014 | 12:35 PM
Ok sweet thanks
Old Apr 23, 2014 | 01:47 PM
Range_Time's Avatar
i was in the same boat and had a AEV unit. ended up getting a trail Dash, setting the jeep back to stock with the AVE, then using the trail dash for the sway bar light and tune. just a thought if you have not purchased your tuner yet, the trail dash does both.
Dave
Old Apr 23, 2014 | 02:10 PM
nthinuf's Avatar
I think the only problem I have ever seen from using two different units was someone semi-recently was correcting tire size using both, then trying to return to stock with only one unit, (or something similar to that) and his 'stock' tire size was messed up. Returned to stock with both, problem gone.
