Superchip 6spd
Hey guys,
I got my 33's with the 3.21s and it is okay but not as powerfull anymore. Also the speedometer is off. I know the superchip can fix this but I also know that superchip can fix the shifting points on the autos. I have a 6-spd and I'm wondering what kind of benefits (other than the speedometer it will provide)??? Thanks yall, Keith |
Originally Posted by klutz1001
(Post 1387210)
Hey guys,
I am still a n00b but I've been doing some reading because I also have 33's with 3.21 gears and my speedo is off and who doesn't like more power?
My understanding is the superpaq's are the BEST They have pre-loaded maps for MPG or for power and for different octanes of gas. It seems most people think they are way better than any of the other chips out there.....of course not much will beat a custom tune but the ability to change tunes with the flashpaq....which you can add later.....to me seems the way to go I open source tuned my Subaru. It would have been nice to be able to switch maps a little easier. I pretty much ran the same one all the time since I didn't want to hook it up to my laptop. I'm not sure how easy it is with the superpaq I will most likely purchase mine in the next few weeks Hopefully someone with more info will also respond |
1) tire size speedo correction
2) Engine tune 3) TPMS tire pressure change and disable 4) crawling engine idle low priority 5) speed limiter 6) data aquisition |
(Post 1387210)
Hey guys,
I got my 33's with the 3.21s and it is okay but not as powerfull anymore. Also the speedometer is off. I know the superchip can fix this but I also know that superchip can fix the shifting points on the autos. I have a 6-spd and I'm wondering what kind of benefits (other than the speedometer it will provide)??? Thanks yall, Keith I don't want to talk negatively about it, I love mine,but i have a 6 speed, 4.10s and 32s. I plan on moving up to 33s w/o re-gearing, but I wouldn't push it beyond that. Especially, not here at high altitude... |
I agree with Atl JK as you still need to get into an rpm range where a programmer is going to provide benefit a little quicker. With 33s you are about 20% under geared and you aren't going to pick up a 20% improvement from a Flashpaq. Sure it will help, but at best it gets you only half the way to where you need to be.
With the huge jump you can make from 3.21s to 4.88s and still be in the range of where your gears aren't too steep, you will drastically change the drivability of your JK. The SC will certainly help, but it's not going to give you that kind of bump. Best of all is that 4.88s are going to give you drivability all the way to a 37" tire and even more although you get into the realm of significantly more modifications. |
Originally Posted by JPop
(Post 1387702)
looks like superchip wins again. man i got to get me one of those
You may benefit by reading two active threads:
Regarding trying to solve final drive ratio problems by increasing HP: https://www.jk-forum.com/forums/modified-jk-tech-2/gears-now-save-ripp-sc-105518/ And for the benefits/functionality/owner feedback of the Flashpaq checkout the Millennium thread: https://www.jk-forum.com/forums/modified-jk-tech-2/superchips-flashpaq-jk-initial-impressions-80188/ |
just thought i would let yall know i ordered mine and its on its way... i will let you know how it does with my 33's and 6sp.. thanks for all the info!
