Superchip fix for temp gauge?
AS you probably know, Jeep programmed the temp gauge to always show straight up / normal, unless it was cold or already overheating (dealer told me this was to make owners think it was always running perfect and to prevent too many calls to the service dept.). Scott from Superchips is willing to look into a fix if there is enough interest.
If you are also bothered by not having a real readout, please post here. If there are others besides me, there could be a solution.
2007 Rubi Unlimited, 42k miles...ScanGauge reads water temp, my range is 194 to 216 depending on situation...fan comes on between 204 and 207...jeep gauge never moves but 1/2 needle below and above middle...200 seems to be middle, installed oil pressure and temp with an oil filter sandwich, works great, gauge is between two center air ducts...jeep should never be without temp and oil pressure readings...
